Platform: J-body
Head gasket questions, please help!!
Old August 7th, 2011, 8:18 PM
1996 cavalier 2.2's Avatar
Default Head gasket questions, please help!!
I noticed antifreeze leaking out of the head gasket ive done some car repair on my cavalier, buy not engine wise, I wnt to replace the head gasket on my own is there like a step ny step process I need to follow? I know I need new headblots is there anything else I need? Also what do I need to take to the machine shop the head cylinder or the block? Thanks guys!!
Old August 8th, 2011, 6:19 AM
Segfault's Avatar
You need a beam-type torque wrench. Clicking type will do, too, but the first one that exceeds beam-type in preciseness is a $500 Snap-On instrument. Yes, all cheaper clicking ones are junk.
You need to make sure your cylinder head is not warped, if it is it needs to be machined. Also inspect it for cracks and some valve job may be in order, too.
Old August 11th, 2011, 3:37 PM
So should I use a beam type torque wrench instead of a clicking one? Also what is the best cleaner to clean the inside and outside of the head cylinder?
Old August 11th, 2011, 4:03 PM
kevinkpk's Avatar
You can use a ratchet type torque wrench or a needle type. Important thing is to adhere to the torque pattern and values, general rule is to torque 1/3 total value on the pattern, then repeat the same till you have the final value.
Old August 15th, 2011, 10:37 PM
I know I need new head bolts when replacing the head gasket, but do I need new bolts for the cam? What else do I need when replacing the head gasket?
Tahoe0159
July 9th, 2015 10:43 AM
DOBERDEWD
December 11th, 2011 11:35 PM
Dads Toy
October 21st, 2011 6:54 AM
2.2cavalier1996
September 27th, 2011 8:24 PM
gulfcoastjoe
May 4th, 2008 12:38 PM
Quick Reply: Head gasket questions, please help!!
