Platform: J-body
Head gasket questions, please help!!
Old Aug 7, 2011 | 8:18 PM
1996 cavalier 2.2's Avatar
Default Head gasket questions, please help!!
I noticed antifreeze leaking out of the head gasket ive done some car repair on my cavalier, buy not engine wise, I wnt to replace the head gasket on my own is there like a step ny step process I need to follow? I know I need new headblots is there anything else I need? Also what do I need to take to the machine shop the head cylinder or the block? Thanks guys!!
Old Aug 8, 2011 | 6:19 AM
Segfault's Avatar
You need a beam-type torque wrench. Clicking type will do, too, but the first one that exceeds beam-type in preciseness is a $500 Snap-On instrument. Yes, all cheaper clicking ones are junk.
You need to make sure your cylinder head is not warped, if it is it needs to be machined. Also inspect it for cracks and some valve job may be in order, too.
Old Aug 11, 2011 | 3:37 PM
So should I use a beam type torque wrench instead of a clicking one? Also what is the best cleaner to clean the inside and outside of the head cylinder?
Old Aug 11, 2011 | 4:03 PM
kevinkpk's Avatar
You can use a ratchet type torque wrench or a needle type. Important thing is to adhere to the torque pattern and values, general rule is to torque 1/3 total value on the pattern, then repeat the same till you have the final value.
Old Aug 15, 2011 | 10:37 PM
I know I need new head bolts when replacing the head gasket, but do I need new bolts for the cam? What else do I need when replacing the head gasket?
Tahoe0159
Jul 9, 2015 10:43 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
Dads Toy
Oct 21, 2011 6:54 AM
2.2cavalier1996
Sep 27, 2011 8:24 PM
gulfcoastjoe
May 4, 2008 12:38 PM
