Need a cavalier expert/ diagnosis expert
So here is the scope, I keep making threads on this topic but I have done a lot over the past 3 months so here is where I am at.
So my car has a rough idle where it bounces between 900 - 1000 rpm (sounds like it has lumpy cams). When you give it gas or just idle it up and a bit and hold it the miss goes away and runs smooth. I have hooked it up to a computer and at idle all cylinders miss across the board, but on idling up the misses clear out. I have replaced coils, plugs, injectors, injector harness, and egr. With these replacements I have squeezed a bit of performance out but still the same rough idle, I have checked vacuum lines as well. I'm wondering if maybe its a bad wire to the pcm but like that a shot in the dark I really have no idea where to go from here. My car is pulling a P0300 which is random misfire and a bank 1 sensor 2 low volts and heater malfunction which is the back 02 (after cat) so don't really know, help would be great
ssumners
Silverado & Fullsize Pick-ups
September 30th, 2012 2:43 PM
pkjosh
November 7th, 2011 8:46 PM
ourbigtruck
March 4th, 2011 8:20 PM
