Computer, Ignition, & Fuel Systems Talk about the control module, ignition system, fuel system and delivery, customization and more.
MECHANICAL OR ELECTRIC FUEL PUMP
Old July 26th, 2006, 12:42 AM
atlbigboi's Avatar
Default MECHANICAL OR ELECTRIC FUEL PUMP
WHATZ GOING ON GUYS,NEW TO THE SYSTEM AND HAD A QUESTION ON WHETHER THERE IS DIFERENCE BETWEEN USING A MECHANICAL FUEL PUMP ON A 87-95 350 2 BOLT 4BBL EMGINE IN A 82 MONTE,OR SHOULD A ELECTRIC ONE BE USED TO FOR BETTER FUEL DIRTRIBUTION MAYBE SOME WAY.LET ME KNOW WHAT YOU GUYS THINK?
Old September 2nd, 2006, 2:44 AM
uncle bill's Avatar
Default RE: MECHANICAL OR ELECTRIC FUEL PUMP
The first thing to check is if You have a mechanical fuel pump boss on the engine and if it's drilled for mechanical pump use including the pump rod between the camshaft and fuel pump. Then You'll need to know if the camshaft has a fuel pump essentric cast into it. With that, It'd be a lot easier to put an electric pump on it ( something like a HOLLEY red pump ) and just be done with it.
adamchaz
December 8th, 2013 1:03 PM
4 bangin
July 31st, 2013 2:44 PM
ExcessiveEgo
May 10th, 2013 7:32 PM
boydog40
November 8th, 2012 8:28 AM
frickenbored
April 18th, 2011 10:28 PM
Quick Reply: MECHANICAL OR ELECTRIC FUEL PUMP
