PO336 crank sensor
Old Aug 23, 2012 | 3:34 PM
expressvan00's Avatar
Default PO336 crank sensor
Hi all,
I have code po336 in a 2000 express 3500 5.7 I changed the sensor 2 times one from advance one from napa looks like same part from mexico should I try one from the dealership to get it runnin again or is there more of a problem with this code?
Thanks.
Old Aug 23, 2012 | 3:51 PM
kevinkpk's Avatar
I think you need to check wireing/connections
Old Aug 26, 2012 | 11:34 AM
Default van fired up new sensor
Hey its running again. After going through the procedure to check for a bad crank sensor which was one of the outside wires had 12vdc the other outside wire had 10vdc and as engine was turned by hand clockwise it was to go from 10 vdc to 0 vdc. It didnt go 10 to 0 so said it was bad. The center wire is ground so checked it with battery positive to get 12vdc. New part came and it fired up no shims required. So even new parts can be bad I ordered an ac delco brand still had same part numbers as advance and napa so no guarantees any of these parts work anymore.
Old Sep 2, 2012 | 5:03 PM
Rufus's Avatar
Default PO336 code
My 2006 Silverado Diesel Duramax is showing this code. Does anyone know where the crank sensor is located on the engine?
JimOmaha
Nov 12, 2022 7:26 PM
bigq11
May 11, 2011 12:53 PM
TCsix
Aug 19, 2010 9:12 PM
bbish0p
Feb 8, 2010 2:17 AM
kidm28
Oct 20, 2006 6:18 AM
