Sofa/Bed Install
Old Mar 9, 2013 | 10:35 AM
DougE's Avatar
Default Sofa/Bed Install
Here is my installation of a Blazin Belltech sofa/bed in my passenger van. Dealing with the factory interior finishes is fairly complex but it can be done. The back folds out and down to make a wider bed. I chose this product because the sleeping position is 78-5/8" x 43-1/2", probably longer than the typical van couch or jack bed.
Attached Thumbnails Sofa/Bed Install-pict0012.jpg
Old Mar 13, 2013 | 4:47 PM
tsbrewers's Avatar
Looks nice.
Brew
Old Mar 18, 2014 | 1:34 PM
contender's Avatar
Default Any thoughts on this bed?
Hi - This is the only instance I could find of someone installing this bed in a van. I am thinking about the same thing and would like to know about your installation experience...how difficult? Can the bed still be folded against the wall? do you think if you trimmed the support legs it could have been mounted a bit lower? Is it sturdy enough for seatbelts? Thanks for any insight!
Old Mar 18, 2014 | 4:28 PM
DougE's Avatar
This install was a little difficult because it was being done in a window van. I had to put some blocking under the wall panels and trim the panel at the rear tire, a/c area to put in the exterior piece. I also had to remove the ductwork behind the lower panels. In retrospect I could have just put blocking under the panels and cut out for the two sofa/bed attachment points.
There no reason why attaching seat belt sets to the floor or to the blocking wouldn't work.
Yes, the bed can still be folded against the wall, but I haven't bothered with the attachment of the retaining straps as I just don't need that feature.
You should be able to lower the sofa/bed to the level of the tire fender.
If you will PM me your email I have a few pics I can send of how it went together.
Old Oct 19, 2016 | 6:23 AM
Joseph Adam Headrick's Avatar
Can you tell me how comfortable this bed is please? Plan on installing one in my 2007 express and I'll be using it daily for about 6 months. Thanks!
Old Feb 13, 2023 | 11:40 PM
Pickel's Avatar
Looks quality , has it held up ?
Old Feb 14, 2023 | 12:11 AM
@Pickel
This person hasn't visited the forum since 2016. It's pretty unlikely that they'll return. Please exercise some judgment before resurrecting old posts.
Old Feb 14, 2023 | 12:32 PM
vinman's Avatar
Welcome to the forum Pickel , tanx for joining us
No worries , just start your own post in the van section and some of us will put in our 2 cents worth about
beds in vans
Cheers ....... Vincent in Ontario Canada
Exhausted
Mar 18, 2012 3:44 PM
Chevie
Nov 7, 2011 5:37 PM
glegeza
Jul 26, 2010 10:29 AM
biglg
Feb 22, 2010 8:37 PM
