slip yoke greasing
Old Nov 16, 2011 | 8:00 AM
etbowhuntr's Avatar
Default slip yoke greasing
what grease should i use to grease the slip yoke splines?..does it matter?...i dont want to eat the rear seal away and get into the case and fluid.
Old Nov 16, 2011 | 8:39 AM
etbowhuntr's Avatar
ttt..
Old Nov 16, 2011 | 9:01 PM
MDTAHOE's Avatar
Professional Mechanic
Why do you want to grease it? Is it getting stuck?
Old Nov 17, 2011 | 8:32 AM
SWHouston's Avatar
You shouldn't need to grease them at all.
The part of the Sleeve of the Yoke, and the Spline Gear of the Yoke and Transmission, are exposed to the Automatic Transmission Fluid or Gear Lube. There's no actual pump that furnishes the Oil back to them, but there's usually a sufficient amount of it available, to keep things Lubed up sufficiently. That's why there is an Oil Seal there. In fact, the introduction of another kind of Lubricant into the Transmission, could cause contamination, and cause you problems in the long run.
Old Nov 18, 2011 | 6:13 AM
etbowhuntr's Avatar
the reason i need to grease it is that i have that "clunk" whn i go from P>D or P>R and if i hit the gas rather than easing into it slowly. ive looked up the cause and it looks to be that the splines on the slip yoke and ouput shaft are slamming together. the temp fix for it is to grease the shaft and yoke to add a cushion between the splines. the FIX if a nickel plated slip yoke.. i cannot however find anything out there that says what type of grease would be best for this. its on a 05 1500 btw....thankyou
Old Nov 18, 2011 | 7:29 AM
MDTAHOE's Avatar
Any grease will work just may not last long. You can get the grease that the dealer sells to lube the steering shaft. It comes in a white siringe
Old Nov 18, 2011 | 11:03 AM
SWHouston's Avatar
et, why don't you try just replacing the Yoke with an OEM first, and pour some ATF in and on it before pushing it in. That oughta help a lot, and if you'll tell me what kind of ATF you're using, I'll see if I can find a heavy grease, which is reasonably compatible with it.
Old Nov 19, 2011 | 5:52 AM
etbowhuntr's Avatar
the OEM is a upgrade to the nickel plated version. i have yet to find one online so, as much as i hate to, i assume its a GM part. which means im gonna have to wait till after christmas to get it so that ill still be able to buiy presents for my kids...idk what fluid is in there now. its at 88k so its time to change it and that IS on the list so whe i do ill prolly go to an amsoil product.
Old Nov 19, 2011 | 11:30 AM
d12cons34's Avatar
greasing your vehicle gives a quite relax to u
hvychev77
Oct 8, 2011 7:56 PM
dmitschke
Sep 19, 2011 5:50 PM
kenj66
Mar 15, 2011 10:32 AM
in2pro
12
Nov 15, 2010 11:40 PM
area1509
May 10, 2009 1:38 PM
