GMT900 Slip Yoke Lubrication
Old Jul 14, 2010 | 6:35 PM
Default GMT900 Slip Yoke Lubrication
Here is an excellent link that snakedoctor found for addressing the clunk that you can get when coming to stops.....
http://www.truckmodcentral.com/forum...ead.php?t=2504
the lube GM PART # 12345879
Old Jul 15, 2010 | 7:47 AM
ousig2408's Avatar
very nice, I am getting mine replaced at the dealership under warranty when they get the part in. I guess they are backordered right now
Old Jul 15, 2010 | 8:22 AM
they are replacing the yoke? what were the symptoms you were having?
Old Jul 15, 2010 | 10:31 AM
ousig2408's Avatar
yes they are replacing the slip yoke with a new one. it sounds like it is rubbing when you go over bumps and the suspension is settling, like a shock problem but it is not that. and I have the "clunk" sound and feel when I slow down and stop at a light - like the drive train is bound up. it is because the splines are dry and catching.
dealership said they have a new design out now that should eliminate having to lubricate the current one repeatedly
Old Jul 15, 2010 | 1:05 PM
Interesting please share any info or part numbers that you can get, cost and the like and post if you can
Old Jul 15, 2010 | 1:25 PM
ousig2408's Avatar
I will update when they get the part in and fix it - I was told it will be covered on the powertrain warranty so no charge.
Old Aug 9, 2010 | 2:52 PM
ousig2408's Avatar
dealer called and said that this should be in shortly. I guess the delay is because the Tahoe and Surburban was not included in the recal/replacment of this part, only the trucks. So until about 1 month ago all the dealers could do was lube the joint for the SUVs. They now can replace the part.
I will update when I get it fixed
Old Aug 10, 2010 | 7:21 AM
SabrToothSqrl's Avatar
Default wow
They still use Slip Yokes? Poor design... they went to a fixed yoke on the Wrangler Rubicon back in '03...
I'm not sure if the cheaper ones are still a slip yoke...
Drop a drive shaft on the trail... lose your transfer case fluid... awesome idea... let's put stress on the transfercase!
Is this problem only affecting '07 Tahoes or should I look under my '09?
Old Aug 10, 2010 | 8:32 AM
ousig2408's Avatar
not for sure, I would think it is the same design for all of the 07+ Tahoe/Suburbans. If you have a "squeek" noise when going over bumps or a "clunk" feel when coming to a stop and starting - like a slow rolling stop. Then that is the issue. basically the driveshaft splines get dry with the current design and need to be lubed again to get rid of the noises.
but once that is done it wont last for long before the same thing could happen again so the dealer said their is a new design for the Tahoes that will eliminate this. mine is a 2wd so I do not know if the 4x4 is a different design?
once I get it fixed I will post exactly what they did for everyone
Old Aug 14, 2010 | 11:22 AM
ousig2408's Avatar
ok got it fixed this morning under the powertrain warranty - 100% better now. I used to have some noise over nearly every slight bump and would have the jerk/clunk feel when coming to a stop. it is all gone now and it feels like a new truck or like it should in the first place. while waiting I was able to lust over the ZR1 in the showroom...
it looks like the wording on the paperwork is "replaced slip yoke and u joint per bulliton 09-04-17-002C"
