Please Help Me!
Please Help Me!
I spliced in a 4 prong wiring harness for a trailer...
Before Splicing:
all lights worked
After Slipicing:
blew a fuse. all lights in rear of truck not working. brakes, turn signals, parking lights, not working...however, they worked, shut off, worked shut off, worked for 5 mins, then shut off for good
After Replacing Fuse:
brake and turn signals work
no license plate and running lights
Help please!!
Before Splicing:
all lights worked
After Slipicing:
Help please!!
RE: Please Help Me!
I did. If I undo the ground wire the brake lights and turn signals dont work. But when I reconnect the ground wire, they work, but the parking lights in the rear still dont work...
RE: Please Help Me!
i cant unhook the 4 way because i spliced them in using those clips that you clamp down. in order for me to take it out, i have to cut out all the wires
remember...
remember...
RE: Please Help Me!
if its the clips that u place the wire in then fold cover over and squeeze to lock then all u have to do is unlock cover pull out the two metal things and it will come apart bot they are hard to reuse i would recommend soldering splices tape with electrical tape then coating good with silicone form a gasket or liquid tape that way u get a waterproof seal and won't have problems with corrosion on down the road but use rosin core solder
beezey
Silverado & Fullsize Pick-ups
November 24th, 2011 4:01 PM
j0nblazeish
Uplander
September 25th, 2009 6:42 PM
