Please Help Me!
Old Nov 9, 2007 | 6:27 PM
mudderfan's Avatar
Default Please Help Me!
I spliced in a 4 prong wiring harness for a trailer...
Before Splicing:
all lights worked
After Slipicing:
blew a fuse. all lights in rear of truck not working. brakes, turn signals, parking lights, not working...however, they worked, shut off, worked shut off, worked for 5 mins, then shut off for good
After Replacing Fuse:
brake and turn signals work
no license plate and running lights
Help please!!
Old Nov 9, 2007 | 6:47 PM
DAVID L. PAUL's Avatar
Default RE: Please Help Me!
remember the white wire is ground recheck your wiring for a short
Old Nov 9, 2007 | 6:56 PM
mudderfan's Avatar
I did. If I undo the ground wire the brake lights and turn signals dont work. But when I reconnect the ground wire, they work, but the parking lights in the rear still dont work...
Old Nov 9, 2007 | 7:07 PM
ok dose the tail lights work when u unhook 4 way connector
Old Nov 9, 2007 | 7:17 PM
mudderfan's Avatar
i cant unhook the 4 way because i spliced them in using those clips that you clamp down. in order for me to take it out, i have to cut out all the wires
remember...
Old Nov 9, 2007 | 7:59 PM
if its the clips that u place the wire in then fold cover over and squeeze to lock then all u have to do is unlock cover pull out the two metal things and it will come apart bot they are hard to reuse i would recommend soldering splices tape with electrical tape then coating good with silicone form a gasket or liquid tape that way u get a waterproof seal and won't have problems with corrosion on down the road but use rosin core solder
vet67coupe
May 10, 2014 11:33 PM
beezey
Nov 24, 2011 4:01 PM
