1990 C1500 P/U possible timing problem
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> I have a 1990 Chevy 1500 PU, 6cyl, 5 speed stick.
Over the last month it was having trouble with acceleration and was bogging down when stepping up speed up or going up an incline. As long as I speeded up gradually it was OK.
I installed a distributor cap, rotor, timing advance module, 6 plugs and plug wires, all new.
This solved 95% of my problem. It runs smoother, but I think the timing advance is still off. Same problem as described.
Did I miss something or does this need to go to a mechanic?
Thanks for your help.
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->
Barry A. Waters
Silverado & Fullsize Pick-ups
May 1st, 2015 11:25 PM
ShadeTreeJack
August 2nd, 2014 12:14 PM
hfdff
August 12th, 2010 5:39 PM
