Anit-Freeze
Anit-Freeze
A friend of mine has a 98 S-10 that froze up due to no anit-freeze.Temp got about 205 before he noticed it,shut it off and now it want start like I said turned off as soon as he noticed. He was wondering why it want start.
Well, if it froze up, it probably blew a freeze plug. If it overtemp to 205, I doubt it did any damage. You need to look at fuel pressure, then spark. Systematically check these things to find out what you don't have which is causing it to not run.
Freeze plugs are also known as soft plugs. Most engines have cast iron blocks, and heads. If the coolent isn't rated at a lower freeze point than the temp, it will freeze. To protect the block, and heads in the water gallies at certain points (usually in an impossible place to get at) there are these plugs that will pop out as the coolent/eater expands to protect the engine. Thats not what is causing your issue.
Mike Sigmond
Silverado & Fullsize Pick-ups
May 2nd, 2009 2:27 PM
buijon
August 2nd, 2007 8:43 AM
