S-10 & Blazer 1982-2005
Anit-Freeze
Old Dec 15, 2012 | 12:19 PM
LoneWolf98's Avatar
Default Anit-Freeze
A friend of mine has a 98 S-10 that froze up due to no anit-freeze.Temp got about 205 before he noticed it,shut it off and now it want start like I said turned off as soon as he noticed. He was wondering why it want start.
Old Dec 15, 2012 | 1:01 PM
kevinkpk's Avatar
I don't understand your statement.
Old Dec 16, 2012 | 7:15 AM
LoneWolf98's Avatar
He's wanting to know how to tell if his motor is ruined. It try's to start that's it,does the motor need replaced?
Old Dec 16, 2012 | 8:04 AM
kevinkpk's Avatar
Well, if it froze up, it probably blew a freeze plug. If it overtemp to 205, I doubt it did any damage. You need to look at fuel pressure, then spark. Systematically check these things to find out what you don't have which is causing it to not run.
Old Dec 16, 2012 | 8:41 AM
does the engine turn over when attempting to start?
Old Dec 16, 2012 | 11:17 AM
LoneWolf98's Avatar
yes and turns just like always.
Old Dec 16, 2012 | 11:23 AM
LoneWolf98's Avatar
Where do you look to check freeze plugs?
Old Dec 16, 2012 | 2:16 PM
kevinkpk's Avatar
Freeze plugs are also known as soft plugs. Most engines have cast iron blocks, and heads. If the coolent isn't rated at a lower freeze point than the temp, it will freeze. To protect the block, and heads in the water gallies at certain points (usually in an impossible place to get at) there are these plugs that will pop out as the coolent/eater expands to protect the engine. Thats not what is causing your issue.
Mike Sigmond
May 2, 2009 2:27 PM
mean327
Jan 5, 2009 12:13 PM
sschnelle
Dec 23, 2007 10:10 PM
buijon
Aug 2, 2007 8:43 AM
Bigjoey71
Dec 22, 2005 1:11 PM
