S-10 & Blazer 1982-2005
Need help s10 cranks but won't start
Old March 19th, 2015, 7:34 PM
Jacob8414's Avatar
Default Need help s10 cranks but won't start
Okay for the last few weeks my 98 s10 2.2L has been acting up! Every now and then it will crank but not start! And sometimes it will start up with no problem! It has new fuel filter and the fuel pump seems to be fine! If you have any idea what it could be please let me know
Old March 19th, 2015, 9:51 PM
When you say it won't start, is that it won't start at all or will it start after extended cranking? Do a fuel pressure check. It could also be the check valve if it starts after extended cranking. When it will not start spray starter fluid into the throttle body. If it runs for a few seconds then it is a fuel problem.
Old March 20th, 2015, 8:45 AM
New User
Awaiting E-mail Confirmation
iorncowboy's Avatar
check the the air filter, check for spark,
Old March 23rd, 2015, 6:07 AM
twostroke91's Avatar
Could be fuel pump if pressure is to high or to low have to do pressure test .
rroyse
May 4th, 2016 11:18 AM
Don12
June 26th, 2011 7:28 PM
fryerdiesel
June 24th, 2011 1:26 PM
PrecisionAuto
November 24th, 2008 11:42 AM
elviejo59
Silverado & Fullsize Pick-ups
August 6th, 2008 8:14 PM
Quick Reply: Need help s10 cranks but won't start
