Tracker 1989-2004
Platform: CAMI (Suzuki)
98 Tracker cranks but won't start
Old May 27, 2008 | 10:58 AM
PrecisionAuto's Avatar
Default 98 Tracker cranks but won't start
Has anyone seen this problem before. I have a 98 tracker that I replaced the distributor crank sensor and ECU. I have spark, compresion, anda good timming belt and tensioner and all is correctly lined up according to all data.The vehicle cranks with bright sparkand no start, just a few back fires out of the intake. dose any one have any ideas?
Old Nov 24, 2008 | 11:42 AM
irdaneel's Avatar
Default RE: 98 Tracker cranks but won't start
Spark, compression, good, how about fuel?
Also, I've seen shops sell the wrong parts, perhaps ones for different models that they think will serve the purpose, but are "clocked" for a different motor, (same part, mounted in a different relative position) causing the timing to be out of whack by anywhere from 120 to 180 degrees. Sometimes they can be "re-clocked" to fit and work.
My Sebring's EGR valve needed to be "re-clocked" to be mounted, but works just fine.
drzen99@yahoo.com
Jan 13, 2019 9:38 PM
rroyse
May 4, 2016 11:18 AM
Ron-tx
Mar 30, 2016 9:22 AM
bigbensteel
Oct 13, 2010 8:33 PM
elviejo59
Aug 6, 2008 8:14 PM
