cold start issue and high idle
Old Oct 3, 2009 | 9:34 PM
  #31
atis's Avatar
darn it...it better not be the fuel pump, its a year old.... ok, tomorrow I do more testing. Since I forgot to mentionthis earlier... 159,000 miles.
Old Oct 4, 2009 | 4:08 PM
  #32
tm4hammer's Avatar
Default powers that be
Bright side ! at least ya got a direction now and accounts for alot of what is is going on! sounds like you are almost there
Old Oct 4, 2009 | 6:19 PM
  #33
atis's Avatar
true I just gotta find 4 hours in my day to work on her. I spend 14 hours a week on the soccer field coaching my 3 teams!!
Old Oct 8, 2009 | 7:59 PM
  #34
atis's Avatar
any tips/short cuts for replacing the fuel pressure regulator?? Plan to replace it in the morning.
Old Feb 2, 2010 | 6:55 AM
  #35
atis's Avatar
UPDATE:
FPR was replaced this weekend...still having a hard start issue...but not as bad (5 seconds vs 15 seconds). However I am not sure if its more of near dead battery (colder then crap here and the Tahoe only moves once a week) so I cant say for sure....that and I need to but a Fuel Pressure Gauge on her to see if I still have the massive leak down problem.
Old Feb 19, 2010 | 9:49 AM
  #36
atis's Avatar
Update...fully charged battery and still having the hard start issues...but when COLD (engine)....replacing fuel pump relay today...figure it cant hurt and it will at least eliminate it as a possible issue.
Old Feb 24, 2010 | 8:12 AM
  #37
atis's Avatar
Fuel pump relay replaced...still have the same issue. Hard starts. I added fuel cleaner (techron) to clean the injectors.
What I am noticing...is white smoke on days under 50*...a little rough idle after I start up and it feels like the darn tranny doenst back down when I take my foot of the gas at times.
Old Feb 24, 2010 | 2:34 PM
  #38
PastorK's Avatar
Sounds exactly like mine. I'm trying to get it figured out also. Fuel filter didn't fix it. I get two codes saying that I'm running lean on both sides of the motor. Curious to see what you find out.
Old Feb 25, 2010 | 7:03 AM
  #39
sargenthp's Avatar
You said a rough idle when cold, but is it OK when it warms up?
No codes for faulty O2 sensors?
I am just wondering if you might have a sticking EGR valve.
Man what a pain in the butt! I hope you get this figured out soon.
Old Feb 25, 2010 | 7:29 AM
  #40
atis's Avatar
No codes, since I started having this issue (and this thread) I have:
1) replaced fuel filter
2) replaced FPR
3) clean airfilter
4) Clean TB
5) Clean IAC
6) recharged battery (just incase)
7) ran Techron in it...twice
Currently I have two bottles of Techron (the treats 20 gal ones) in the tank and ran her down to half a tank, then added 5oz of Sea Foam and refilled her...the injectors are going to be clean so I can eliminate them from the trouble shooting process.
PastorK...check your fuel pressure...should be around 60lbs. YOu might have a weak fuel pump or a weak FPR.
Would a stuck EGR cause cold start issues? I can crank her for 10 seconds and it wont catch. Stop and thry again and she start in 5 seconds.
