S-10 & Blazer 1982-2005
S10 engine hesitates and struggles
Old May 9, 2006 | 3:39 AM
sparrow's Avatar
Default S10 engine hesitates and struggles
I have 96 s10 4.3L V6. When I reach a constant driving speed and my rpm's are around 2200 the engine starts to hesitate and struggle however when I accellerate or decellerate there is no problem. I gave it a tune up plugs, wires, cap, rotor, fuel filter, air filter and pcv valve and this did not help. Any suggestions on what the problem is or how to fix it would be appreciated.
Thanks
Matt
Old May 15, 2006 | 11:42 AM
5.7Lblazer
Guest
Posts: n/a
Default RE: S10 engine hesitates and struggles
the same thing happens to mine but i have ablazer with a 350 in it
and when i stomp it it boggs downs (hesitates) you could possibly
need to warm up or it could be timing it could be a couple diff. things
Old Aug 8, 2006 | 12:17 PM
EscalonJon's Avatar
I had an issue with a Saturn a few years ago where I thought it had a bad timing problem. It was very sluggish and accelerated very poorly. It even knocked like the timing belt was going bad or something. It drove me crazy and I thought I had a real expensive fix on my hands. It turned out that the pellets and structure inside the catalytic converter had come loose. I got it replaced and it was like a new vehicle again. Sometimes you can knock on the converter with a hammer or 2x4 and hear the loose items inside rattle around.
Just a thought...Maybe rare, but it does happen.
Old Sep 17, 2006 | 1:48 AM
sparrow's Avatar
thanks for the response i took it in and told them it might a catalytic problem and sure enough it was. if you can remember please let me know how much it cost you, the estimate they gave me was around $750 cad. including taxes. thanks for the info
Twedledee5
Feb 26, 2015 2:16 PM
kirk88
Jul 21, 2011 8:49 PM
UnRumble
Feb 15, 2010 3:39 PM
jjhearn
Sep 21, 2009 10:09 AM
TXAngel06
Sep 18, 2007 8:36 AM
