88 celebrity warm engine issue
Old Aug 16, 2008 | 11:57 AM
spinner074's Avatar
Default 88 celebrity warm engine issue
my celebrity runs very rough when it has reached operating temp, then turned off for a short period of time, it starts up idleing rough and eratic until engine is raced then it seems to clear up. it starts up with NO problem when its cold ( not ran overnight) A mechanic ruled out the computer is not putting out a rpm signal, he replaced with new one and no change he also replaced crankshaft sensor, I have replaced coolanttemp, oxygen, map , tps sensors and no improvement, all this is costing me more than what the car is worth but I cannot afford to buy another car at this point, any ideas would be a big help, Thanks ....John
Old Aug 20, 2008 | 11:41 PM
spinner074's Avatar
Default RE: 88 celebrity warm engine issue
could my coil packs or ignition module be going bad??
Old Aug 21, 2008 | 9:22 PM
ORIGINAL: spinner074
+1
Old Aug 22, 2008 | 2:23 AM
spinner074's Avatar
+1 ?? meaning? I am going to replace both the control module and the 3 coils, I ordered the generic brand which was cheaper, will it run any better??
Old Aug 22, 2008 | 6:57 PM
+1 means I agree with that statement
It will only run better if thats what is causing the problem
Old Aug 22, 2008 | 9:20 PM
spinner074's Avatar
well funny thing happened that convined me it is the ignition module , I disconnected the 3 harness connections one night, then next day I cleaned the contacts ( they weren't really dirty ) and reconnected them and car ran better for a day or 2, I don't understand why but I read that same thing happened to someone else wrote in a simular formum,Does this make any sense? the 3 connections were all tight and not corroded at all.
Old Aug 24, 2008 | 1:31 AM
spinner074's Avatar
well now i'm thinking my Eprom may be bad so I ordered a stock one for my specific ecm, so I have question , what should I try first or should I say if my ICM is bad will it kill the new EPROM and vise versa? so Should I install both the new parts at same time, or is there a risk of one damaging another? (possiblby bad ICM with new EPROM or new ICM with possibly bad EPROM) another reason I got a new Eprom is because I'm not sure if former owner did a speed densidy conversion and didn't put any id or stickers saying it was done, I assume it was converted because The maf relay had been removed and when My mechanic scanned my ecm , he got eratic readings which is descriibed in a article I read on a speed densidy conversion. so with stock EPROM the system would use the maf and its relay, and also a stock IAC which I have bought already. This car has me confused but I think I'm on the right track, I hope
Old Aug 25, 2008 | 4:16 AM
spinner074's Avatar
Anybody got any thoughts on all this?
Old Sep 18, 2009 | 10:26 PM
onltainments's Avatar
Thankfully, the Hills honey didn't have to worry about any stalkers last night when she dined at the West Hollywood eatery, though she might have gained a few more admirers after parading around in this scorching hot getup!
olderndirt
Jul 3, 2014 10:13 PM
Rusty nut
Jul 12, 2013 11:54 PM
itsmacintosh
Mar 7, 2010 4:11 PM
acheo
Jul 8, 2009 7:34 PM
kc8zdf
Jul 1, 2006 2:10 AM
