2001 4x4 Transfer Case Questions
Old Nov 20, 2008 | 5:49 PM
jraquel's Avatar
Default 2001 4x4 Transfer Case Questions
Hello All,
I am a new member and hope someone can help me out.
I have a 2001 Silverado4x4 that seems to not be going into 4 wheel drive now. Has been working for several years but now does not pull with the front wheels at all.
I want to repair it myself and have looked everywhere I can think of to get a "drawing" of the inside of the transfer case and the Case where the actuator is, so as to get an idea as to what is inside and how it works, before taking it out of the truck, but can not seem to locate any drawings or pictures. Anyone know where I might could get these type drawing/pictures?
I have changed the actuator per recommendations of several mechanics, even per a Chevrolet dealers mechanic, but still no luck.[]
I see there is a "motor" actually on the transfer case and was wondering if someone knew what exactly this motor does. Is the transfer case geared or chain driven?
I have jacked the truck up where all four wheels are off the ground and can actually stop the front wheels, both at the same time, when the 4 wheel drive is engaged. Is this supposed to be or does this tell me nothing. The driveshaft from the transfer Case to the front wheel drive gearbox stops also. Does this mean something is wrong in the Transfer Case?[8D]
Thanks,
jraquel
Old Nov 20, 2008 | 9:21 PM
ukrkoz's Avatar
Default RE: 2001 4x4 Transfer Case Questions
doe the light on the switch come up when in 4HI mode? could be just switch, those are notorious. you should hear actuator - motor - buzz and click when Tcase does its job. check the plug on actuator.
Old Nov 21, 2008 | 11:04 AM
jraquel's Avatar
Light comes on
Can hear and feel the motorrespond and attempt toengage
can feel and hear the actuator respond and appear to engage
How do I confirm the switch is not the problem if the motor and actuator are responding?
Thanks
Do you know if this Transfer Case is chain driven or gear driven?
Old Nov 21, 2008 | 2:56 PM
therewolf's Avatar
If the motor and actuator are responding, are they not activated by the switch? Sounds like the problem is at the xfer case. Not for nothing, but this exact problem is the reason most experienced 4WD truck owners prefer the manually actuated xfer case to the pushbuttons on the dash. This problem is unfortunately all too common, and it has an aggravating habit of cropping up at the least desirable of times.
Old May 11, 2012 | 5:04 AM
garryross's Avatar
Ito am experiencing problems with my transfercase in not engaging i hear the actuator motor turn. I think it could be a sheered key on the actuator gear. Is there a common problem with these transfer cases? oh and the light just blinks when i put it in 4 high or low. Please help !
Old May 11, 2012 | 11:42 PM
Doug Roberts's Avatar
Mine won't go in 4x4 unless I am in n
CPAKESHA
Nov 27, 2012 9:31 AM
cwbyjnky
Jan 17, 2012 9:31 PM
gunner5
Dec 25, 2011 12:46 AM
1991jimmy4x4
Jul 8, 2011 12:45 AM
mavrickmechanic
May 6, 2011 9:42 AM
