K5 Blazer 1969-1994
Platform: Truck, GMT 400
Transmission Identification
Old Jun 5, 2009 | 4:59 PM
dschlact's Avatar
Default Transmission Identification
I recently purchased a 1988 K5 Blazer that has had some work done to it over time. I am trying to get an inventory of the major systems so I know what I have. I do know I have a Jasper GMC 350 5.7 L V8. I know the transfer case and Tranny were replaced with a Jasper as well, but I'm having a hard time identifying what I have.
Any ideas for determining what kind of tranny I have...i suspect it is a 700r4 or TH400 as those are the common tranny's for this model.
Ideas for transfer case ID are appreciated as well.
I have already ID's front and rear differentials as 10 bolt GM Coporate.
Old Jun 5, 2009 | 6:45 PM
Mike Sigmond's Avatar
ROTM Coordinator
It should be in this area in the picture...
This is just an example of one in the late 80's
Transfer Case
All transfer cases have a build tag attached to the case.
On the NP205, it is attached to the bolt retaining the Power Take Off (PTO) cover.
On the NP231, NP233 and NP241, it is attached to the rear case half.
On the NV241 and NV243, it is attached to the rear case half. On the Borg Warner 4401/4470, it is attached to an extension housing bolt.
Old Jun 5, 2009 | 6:50 PM
ROTM Coordinator
If you get your ID's they can be looked up to see what model it is.
Old Aug 19, 2009 | 8:34 AM
if you post a pic of your transfer case it will easier to identify, the same with your tranny,it is an automatic right?if the shift pattern is on your t case handle sometimes you can tell which case it is by the shift pattern.keep us informed...as for the tranny you could climb underneath and count the bolts around the pan...the transfer case couls be an np208...pics will help since ther are many different ways this truck could be..do you have manual locking hubs in front?or full time
Attached Thumbnails Transmission Identification-hpim2155.jpg   Transmission Identification-anp203_.jpg   Transmission Identification-anp205.jpg
Old Jul 30, 2010 | 12:02 PM
viljo's Avatar
Hi, my first post, I'm borrowing the thread. Where can I see what the ID numbers mean. Is there a list some where? my transmission 5TK293A.
Old Aug 1, 2010 | 11:36 AM
2wd-K5's Avatar
to both questions: how many times does it shift? 4 times? 700r4, 3 times? and pan is square with a corner cut off: turbo 350, if the pan looks like the state of texas then turbo 400
littlepapapump_04
Sep 7, 2012 5:56 PM
ImpalaSS62
Dec 29, 2010 1:44 PM
travb1999
May 27, 2010 8:22 PM
Stelianos07
Oct 27, 2008 8:15 PM
tbear
Astro
Sep 22, 2008 4:43 PM
