License Plate Bulb Removal
Old Oct 14, 2009 | 4:17 PM
mikew2069's Avatar
Default License Plate Bulb Removal
I'm replacing my license plate bulbs with LEDs but I'm not sure how to get the originals out. I unscrew the plastic housing and then there's the bulb in a white setting. Do I just get pliers and yank it that whole piece out? I'm just afraid I'm going to break something.
Old Oct 14, 2009 | 6:57 PM
carefully remove the bulb from the socket.
Do not unscrew the socket....if you do, you must remove the applique that houses the socket, and 90% of the time, they break removing the bolts for them
Old Oct 14, 2009 | 7:34 PM
mikew2069's Avatar
Oh, so do I actually grab the bulb with my fingers and just pull it out? I was always under the impression that I shouldn't touch the actual bulb.
Old Oct 15, 2009 | 2:28 PM
use latex gloves or a rag if you're worried about it.
The oil on your fingers can make them get too hot and burst, but I have never seen it happen on bulbs other than headlight bulbs
Old Oct 18, 2009 | 9:18 AM
mikew2069's Avatar
Great. thanks!
Old Oct 18, 2009 | 10:14 PM
I think the finger oil or other contamination is only a problem on halogens due to the higher temp (creates a hot spot) and maybe the glass is different. Quartz??
Old Oct 20, 2009 | 11:17 AM
mikew2069's Avatar
I had to show some love with a follow up picture. I can't believe it was so easy to take that bulb out. I was yanking the whole bulb housing at first and probably almost broke the hell out of it.... But man, LEDs are the way to go!
Old Oct 22, 2009 | 1:22 PM
OK now we need source and P/N.
Looks real good.
Kathy97330
Apr 12, 2014 9:31 PM
BigBlackTruck2014
Dec 9, 2013 9:26 AM
Fire & Ice
Feb 21, 2012 9:39 PM
fisch79
Feb 10, 2008 8:34 PM
ltzmego
Sep 26, 2006 10:58 PM
