1999 Silverado won't start Need help please
I am needing some help . I'm stumped . I have a 1999 Silverado 5.3l automatic . It will not start at the ignition switch. You can jump out the cellinoid at the starter and it will start and run fine . If you drive down the road it takes off in second gear and will not shift into over drive . Also the instrument cluster is not working correctly . The only gauges that are working are the voltage and oil pressure . If you press and hold the reset for the odometer then all the gauges start working fine . I hooked up a matco scan tool and it wouldn't read . It kept saying the truck wasn't hooked up to the scanner . Any info would be great .
The truck not being hooked up to the scanner is probably a blown fuse. Check the cigarette lighter fuse as the scan port is powered through there. I would check all the fuses as that might be part of your other problems. More than likely you need to repair or replace the instrument cluster or repair the wiring going to it.
[QUOTE=3blacksilverados;270782]I am needing some help . I'm stumped . I have a 1999 Silverado 5.3l automatic . It will not start at the ignition switch. You can jump out the cellinoid at the starter and it will start and run fine . If you drive down the road it takes off in second gear and will not shift into over drive . Also the instrument cluster is not working correctly . The only gauges that are working are the voltage and oil pressure . If you press and hold the reset for the odometer then all the gauges start working fine . I hooked up a matco scan tool and it wouldn't read . It kept saying the truck wasn't hooked up to the scanner . Any info would be great .[/QUOTE DID YOU EVER REAL THIS PROBLEM? I JUST BOUGHT A TRUCK THAT IS DOING THE EXACT SAME THING. I THOUGHTS-N-PRAYERS IT WAS THE IGNITION SWITCH SO I BOUGHT A USED STEERING COLUMN AND NOW I HAVE TO REDO THE SECURITY SYSTEM BUT IT DOESN'T SEEM TO OF FIXED MY PROBLEM
[QUOTE=Robbie Saunders;313839]
does it crank over and not fire or do you get a no crank,just asking.
mark_b10
August 17th, 2010 7:30 AM
10gunman
Silverado & Fullsize Pick-ups
February 12th, 2009 7:17 PM
