1999 Silverado won't start Need help please
Old Mar 12, 2014 | 7:29 PM
3blacksilverados's Avatar
Default 1999 Silverado won't start Need help please
I am needing some help . I'm stumped . I have a 1999 Silverado 5.3l automatic . It will not start at the ignition switch. You can jump out the cellinoid at the starter and it will start and run fine . If you drive down the road it takes off in second gear and will not shift into over drive . Also the instrument cluster is not working correctly . The only gauges that are working are the voltage and oil pressure . If you press and hold the reset for the odometer then all the gauges start working fine . I hooked up a matco scan tool and it wouldn't read . It kept saying the truck wasn't hooked up to the scanner . Any info would be great .
Old Mar 13, 2014 | 11:35 AM
The truck not being hooked up to the scanner is probably a blown fuse. Check the cigarette lighter fuse as the scan port is powered through there. I would check all the fuses as that might be part of your other problems. More than likely you need to repair or replace the instrument cluster or repair the wiring going to it.
Old Mar 13, 2014 | 6:25 PM
I checked all fuses and relays and wiring . All looked fine . The truck ran fine . The odometer would stay blank but other then that I never had a problem . It sits parked in the winter but I try to drive it or at least start it a couple times a month . I went to drive it last week and it just wouldn't start. I checked the battery and the starter .
Old Dec 31, 2015 | 3:02 PM
Robbie Saunders's Avatar
[QUOTE=3blacksilverados;270782]I am needing some help . I'm stumped . I have a 1999 Silverado 5.3l automatic . It will not start at the ignition switch. You can jump out the cellinoid at the starter and it will start and run fine . If you drive down the road it takes off in second gear and will not shift into over drive . Also the instrument cluster is not working correctly . The only gauges that are working are the voltage and oil pressure . If you press and hold the reset for the odometer then all the gauges start working fine . I hooked up a matco scan tool and it wouldn't read . It kept saying the truck wasn't hooked up to the scanner . Any info would be great .[/QUOTE DID YOU EVER REAL THIS PROBLEM? I JUST BOUGHT A TRUCK THAT IS DOING THE EXACT SAME THING. I THOUGHTS-N-PRAYERS IT WAS THE IGNITION SWITCH SO I BOUGHT A USED STEERING COLUMN AND NOW I HAVE TO REDO THE SECURITY SYSTEM BUT IT DOESN'T SEEM TO OF FIXED MY PROBLEM
Old Jan 1, 2016 | 1:47 PM
chevy55's Avatar
[QUOTE=Robbie Saunders;313839]
does it crank over and not fire or do you get a no crank,just asking.
mark_b10
Aug 17, 2010 7:30 AM
fire5
Apr 27, 2010 6:31 PM
apche024
Aug 29, 2009 4:48 PM
bracca
Jul 12, 2009 6:14 PM
10gunman
Feb 12, 2009 7:17 PM
