Notices
Brake problem
Old August 11th, 2012, 12:32 AM
ETSA Miller's Avatar
Default Brake problem
When I hit my brakes, when I'm almost completely stopped, I get this bad vibration in the brake pedal and the brakes either weaken or pull to the left. Anybody know what this is? It has brand new shoes and rotors.
Old August 11th, 2012, 1:57 PM
year, model, 1500, 2500??
new brakes front and rear? rear disc or dums?
if new drums; I bet you bought aftermarket.
If we install aftermarket drums on a chevy p/u; we always machine new drums cause they're junk...typically out 0.007" new
Old August 11th, 2012, 5:11 PM
spyncycle's Avatar
Sounds like the left caliper is sticking. The bolts weren't lubed.
Old August 11th, 2012, 5:31 PM
kevinkpk's Avatar
Calipers have been known to lockup. This wouldn't be near the first one to do so.
Old August 11th, 2012, 7:13 PM
for the pull yep...could also be drums not set up equally or one side star wheel adjuster seized or not working.
if i only knew the brake set-up the truck has!!
Old August 11th, 2012, 7:43 PM
kevinkpk's Avatar
He stated new rotors, I assume disc.
Old August 12th, 2012, 8:16 AM
Alright, its disk brakes all around. I didnt mess with the back ones because naturally the front one wear faster. But the front has new brakes and rotors. The abs light is also on i just noticed.
Old August 12th, 2012, 8:54 AM
Did you replace the ABS sensors? Mine did exactly that and it was a bad ABS sensor. Don't buy the real cheap ones because that's what they are, real cheap and don't work right.
Old September 5th, 2012, 1:37 AM
kerry1shah's Avatar
Hello
In my car there is problem of low break.
Please suggest me some idea.
Slobby Baymon
November 12th, 2013 11:52 PM
cmcbride
Avalanche
August 8th, 2012 3:12 PM
Thad W. Posey
June 15th, 2012 9:21 AM
tom5170
March 19th, 2010 11:57 PM
Quick Reply: Brake problem
