Notices
Sponsored by: DashLynx
Cruise Control Problems on a 2008 Silverado
Old October 13th, 2011, 11:54 AM
psupgm's Avatar
Default Cruise Control Problems on a 2008 Silverado
Anyone have an idea what the cause of my cruise control not engaging unless I use my foot to pull the brake pedal up after braking? It doesn't appear the pedal moves at all when I do this but the Cruise Control will only work when I do this. Thanks!
Old October 13th, 2011, 5:54 PM
EinST's Avatar
Welcome to the forum. It sounds like you've found your problem. The brake light switch actually has two switch circuits, one for the BCM and the other, the ECM. I think the one for the BCM is not closing properly which causes the BCM to ignore the cruise control signals from the buttons on the steering wheel.
Old October 14th, 2011, 7:41 AM
psupgm's Avatar
Thanks! I assume just replacing the switch we solve the problem?
Old October 14th, 2011, 11:36 AM
EinST's Avatar
It's probably the switch if you see signs of excessive dirt or water intrusion (rust on the brake pedal). Also, try repositioning the wiring harness to make sure there's nothing funny going on at or near the switch electrical connector.
Old October 15th, 2011, 8:30 PM
psupgm's Avatar
Cleaned it and creased it, all is working well. Thanks for your insight.
Old October 15th, 2011, 8:46 PM
EinST's Avatar
You're quite welcome. Hope that's all there's to it.
Old October 3rd, 2013, 3:40 PM
stu carlon's Avatar
I have the same issue. I just installed a new switch and it didnt fix the problem. Im going to have my mechanic friend check for a code. I'll update soon.
Old September 30th, 2015, 9:54 PM
Asnyder's Avatar
I have a 2008 3500 HD WT. I want to replace the steering wheel with one that has cruise control buttons. Is the truck prewired for cruise control?
crwalker2
92
November 23rd, 2023 5:01 AM
Relayer56
Avalanche
18
March 29th, 2021 10:43 AM
GradyCheek
22
February 28th, 2018 7:21 PM
Swampy
19
September 23rd, 2016 9:49 AM
sssilverado23
August 30th, 2012 3:09 PM
Quick Reply: Cruise Control Problems on a 2008 Silverado
