Notices
Sponsored by: DashLynx
Moaning Sound Only on Left Turns
Old March 24th, 2012, 1:47 PM
Soules75's Avatar
Default Moaning Sound Only on Left Turns
I have a 2004 Silverado 1500 crew cab and almost every time I make a left turn there is a loud moaning/rubbing sound and the steering wheel slightly vibrates. I had my wife turn the wheel over and over to the left while I listened with the hood open and I am almost certain I have pinpointed the source of the problem, but I don't know enough about trucks to be sure.
There are 2 hoses/lines below the battery that shake whenever I hear the noise. Are these power steering lines? What are these lines for? Does anyone have any ideas?
I am not low on PS fluid and it never ever makes the sound on right turns, only left. I also lifted the truck up and felt for play in the front tires, but they were both solid. It's not the steering knock as I already tried lubing the intermediate shaft a while back. It's more of a moan or groan than a knock. I feel like it has to be related to the hoses shaking whenever I hear the noise...
Old March 12th, 2013, 7:06 AM
Tarheel4life's Avatar
Did you ever find a solution to your steering problem? Mine is doing the exact same thing. Thanks for any help.
Old March 12th, 2013, 2:34 PM
Fishinfooleric10@aol.com's Avatar
Sure its not the front end, sounds like a hub to me and if you haven't figured it out post a video and I am sure someone can figure it out.
Old March 12th, 2013, 7:09 PM
tyleralt56's Avatar
Default wheel bearing
Sounds like a bad wheel bearing to me.
Old March 13th, 2013, 7:17 AM
Thanks for the help. I'll check the hub/bearing
Old August 16th, 2013, 7:26 PM
Zeb71's Avatar
I have the same noise. It seems to be coming from the power steering pump. Sounds like Chewbacca during left turns only.
Old November 25th, 2014, 5:41 PM
Soules75's Avatar
Hey guys, it's been a long time but I thought I stumbled upon this thread doing a google search for a new issue i'm having with my truck and thought I would share that I did find the steering noise issue. I was getting my oil changed and thought what the hell, i'll have them replace my power steering fluid while they are at it...and sure as ****, I drove away in silence. No more noise ever since!
Hopefully this helps someone down the road.
Old November 26th, 2014, 12:05 PM
nauticstar87's Avatar
Thanks for the feedback. Doesn't sound like a bad idea once I get my truck running again. Ol' girl had been beginning to whine.
Old November 30th, 2014, 9:27 AM
ChevyKidAustin2000's Avatar
Default I Don't think so...
My truck is doing the same thing and i replaced both fronts and it still makes the sound only going left. so if anyone has any other input, please help!
rivero32
September 25th, 2012 12:48 PM
2001Chevy
May 11th, 2009 11:34 AM
derekf
April 24th, 2009 9:57 PM
2003burbnh
January 29th, 2008 12:09 AM
jordan69s
10
June 1st, 2007 11:08 AM
Quick Reply: Moaning Sound Only on Left Turns
