4l60e
Old Aug 25, 2012 | 12:10 PM
cb1's Avatar
cb1
Default 4l60e
I have a 1995 Silverado 2wd. The tranny went out at 282K. I bought a tranny from a friend that matches up except for the neutral safety switch is different. Mine is located on the shifting shaft and the one I bought must be out of a 94 or older. Is there anything I can do to make this work?
Thanks
Old Aug 25, 2012 | 11:27 PM
chevyguy1523's Avatar
can you cut the plug and rewire it with your nss ?? can he??
Old Aug 26, 2012 | 11:14 AM
cb1's Avatar
cb1
I don't know what can be done. I know the plug at the bottom is for back up lights. but the upper plug has 4 wires going to it and I dont have a clue what they are for. I'm use to the older Turbo 350/400's, before all of this electronic stuff.
Old Aug 26, 2012 | 12:14 PM
what year is the new trans?
Old Aug 26, 2012 | 2:04 PM
cb1's Avatar
cb1
I'm not sure. It has the round plug on the right side like my 95 does, The numbers above the shifter is 8680517.
Old Jun 13, 2018 | 11:49 PM
David C's Avatar
[QUOTE=cb1;224905]I have a 1995 Silverado 2wd. The tranny went out at 282K. I bought a tranny from a friend that matches up except for the neutral safety switch is different. Mine is located on the shifting shaft and the one I bought must be out of a 94 or older. Is there anything I can do to make it work?
If you are able to plug it in put the vehicle in natural and try to start it if it turns over and and starts then the nss is good
abqgolfer
Aug 27, 2011 11:30 PM
oppelousas
Jul 25, 2007 1:46 PM
mixerpilot
Jul 4, 2007 1:38 PM
rfishbone
Jun 26, 2007 1:43 PM
dragondad
Jan 1, 2007 3:27 AM
