Notices
Sponsored by: DashLynx
service engine code P1345 cam positioner sensor
Old February 14th, 2011, 10:38 AM
aquarius44's Avatar
Question service engine code P1345 cam positioner sensor
I have a 98 Silverado with 217,000 miles. I bought the truck new and it is in good condition. The service engine light comes on immediately after resetting codes with a scanner. The code that shows on the scanner is P1345 and in checking the codes it is the cam positioner/crank positioner correlation. I removed the distributor cap to replace the cam positioner sensor and found that one screw had come out on the distributor cap and the distributor cap was broken and a pin in the distributor cap was bent. I replaced the sensor,cap and rotor. I restarted the engine and had the same results with the service engine light. I replaced the crank positioner sensor with the same results.
It won't pass emissions with the service light on.
Is it possible that the metal plate on the distributor shaft was moved when the screw came loose and caused the damage to the rotor and cap?
Any help would be greatly appreciated.
Old February 14th, 2011, 10:53 AM
jimmydow1's Avatar
you need to have the timing checked, It is done electronically with a scanner? but it is possible you may have distibutor gear damage
Old December 31st, 2013, 4:51 PM
Benito Gomez's Avatar
where is the crank and cam sensors located and how do you know if they are bad cause we have no trouble starting or hard cranking problem
Old January 2nd, 2014, 10:41 PM
Chris9793's Avatar
mine just was doing that a few weeks ago, the fix was to jump the gears and turn the distributor a little bit to set it. it had been bumped over when changing the fuel pressure regulator. i had the P1345 code too that came on each time it started and idled down to its 1000 rpm or so idle spot
DrummerBoy
1988 - 1998 (GMT400)
25
February 15th, 2024 4:50 PM
norwegianTrucker
February 13th, 2024 3:37 PM
Ryanater
August 14th, 2012 1:16 AM
Jason S Jackson
12
August 9th, 2012 9:15 PM
sushibog66
August 17th, 2009 4:24 AM
Quick Reply: service engine code P1345 cam positioner sensor
