2007 Suburban LTZ - water above the rear seat seat belt
and dripping out of the seat belt assembly. Very random, no idea - has to be a seal issue with the door, right? This happened after a rain - any ideas or similar experiences?
Official GM Rep
“73shark” offers a good suggestion. Is the floor wet at all? Driver’s side?
Louis
GM Customer Service
Professional Mechanic
Open the sunroof, take a cup of water or two and pour it in the area around the sunroof. The water should drain quickly . If it does not the sunroof drains are clogged. Sunroofs are not water tight. After enough water builds up it leaks into the headliner especially when you start driving. This is a very common occurrence, as I see it at least once a month on all makes and models. We usually use compressed air to blow them out. Every once and awhile we must disassemble to find the other end to open back up.
knucklebust
Silverado & Fullsize Pick-ups
June 12th, 2010 7:21 PM
jzlharvey
December 28th, 2007 10:35 PM
