2007 Suburban LTZ - water above the rear seat seat belt
Old Dec 24, 2012 | 8:03 PM
gamecock's Avatar
Default 2007 Suburban LTZ - water above the rear seat seat belt
and dripping out of the seat belt assembly. Very random, no idea - has to be a seal issue with the door, right? This happened after a rain - any ideas or similar experiences?
Old Dec 24, 2012 | 10:07 PM
I'd be more inclined to suspect the luggage rack mounting holes. You can check you door seals w/ a dollar bill also tho.
Old Dec 27, 2012 | 1:57 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> gamecock,
“73shark” offers a good suggestion. Is the floor wet at all? Driver’s side?
Louis
GM Customer Service
Old Dec 28, 2012 | 4:04 PM
Do you have a sunroof? if so its possible the sunroof drain hose has come loose or has broken at that point....
Attached Thumbnails 2007 Suburban LTZ - water above the rear seat seat belt-capture.jpg
Old Dec 29, 2012 | 8:20 PM
gamecock's Avatar
it's rained twice since this happened and no water. here is a picture of where the water was
Old Dec 30, 2012 | 7:14 AM
I would pull the column cover and see if you can peak between the liner and roof...
Old Dec 30, 2012 | 4:15 PM
MDTAHOE's Avatar
Professional Mechanic
Old Dec 31, 2012 | 7:13 AM
gamecock's Avatar
Yes I do
Old Dec 31, 2012 | 9:51 AM
Check out the post above with the sunroof drain hose location, its probably leaking at that point
Old Dec 31, 2012 | 6:14 PM
MDTAHOE's Avatar
Open the sunroof, take a cup of water or two and pour it in the area around the sunroof. The water should drain quickly . If it does not the sunroof drains are clogged. Sunroofs are not water tight. After enough water builds up it leaks into the headliner especially when you start driving. This is a very common occurrence, as I see it at least once a month on all makes and models. We usually use compressed air to blow them out. Every once and awhile we must disassemble to find the other end to open back up.
Typerod
Aug 8, 2013 7:24 PM
sardarkhan
May 16, 2012 3:02 PM
RJK
Jan 11, 2012 7:46 PM
knucklebust
Jun 12, 2010 7:21 PM
jzlharvey
Dec 28, 2007 10:35 PM
