Bose Audio Wiring Diagram
Old April 22nd, 2008, 9:18 PM
rawdog@cinci.rr.com's Avatar
Default Bose Audio Wiring Diagram
I have a 2003 Z-71 Tahoe equipped with the Bose Audio System. I'm desperately trying to add an additional amplifier for a sub box. I need the wiring diagram from the head unit. The plug I have has slots A-1 thru A-12, and B-1 thru B-12. Can any one help me please........
Old April 23rd, 2008, 4:27 PM
Banned
shawnvw's Avatar
Default RE: Bose Audio Wiring Diagram
If you go into the center console, you already have 2 subs there. If your amp has a high level input, all you need to do is wire a couple speaker leads to the sub wiring, and run them to the amp. If you don't have a high level input, you can use a converter to change the high level signal to a low level signal that you may connect RCA's to.
The left sub is
Lt Grn\Blk(-)
DkBlu\Wht(+)
The right is
Dk Grn (+)
Lt Blu\Blk(-)
Old April 23rd, 2008, 9:12 PM
Craven Moorehead's Avatar
This may be a solution to your problem. I will be using this when adding a amp & subs to my LTZ.
http://www.jpcustoms.com/store/custo...307&page=1
Old May 4th, 2008, 5:25 PM
I found the amp, I think the speaker wire colors you gave me are indicated on the the passenger side plug in. I really need the amp turn on wire color as well please.
blaker5 (April 6th, 2022)
Old May 4th, 2008, 6:32 PM
Banned
shawnvw's Avatar
If you do not have RPO code Y91(check the glove box), you can get the amp turn on wire at the radio, in a gray connector,pink wire,pin B3, or at the amplifier itself in the bigger of the 2 gray connectors, pink wire, pin B11.
If you do have RPO code Y91, then the radio and amplifier turn on via data, so your best bet is to go to the ign switch
Old June 26th, 2011, 9:42 PM
adav123's Avatar
Default 04 Suburban
I think my amp is not working any more. How can i check to see if thats the problem?
Old March 24th, 2020, 9:18 AM
Sarge2008's Avatar
Default 2005 Suburban touchscreen radio
I have a 2005 Suburban with Bose audio with the touchscreen head unit. How do I either wire in an amp or replace the factory head unit with an aftermarket stereo? I cant find any kind of wiring adapters for it.
Old March 25th, 2020, 1:02 AM
Welcome to the forum.
Did you try Crutchfield?
Old April 1st, 2020, 9:56 AM
Sam Fazzina's Avatar
jpcustoms.com
The listed URL is an AD ....visiting repeatedly it shows advertisements
07LT3BEE
July 6th, 2022 10:42 PM
AshleyT@
Equinox
September 9th, 2018 4:57 PM
Ledfoot86
April 1st, 2013 8:16 PM
gmlover
November 4th, 2009 4:32 AM
silveradolt1
Audio/Visual Electronics
March 20th, 2008 7:17 PM
Quick Reply: Bose Audio Wiring Diagram
