Diagnostic Trouble Code (DTC) Complete list
Old January 18th, 2007, 7:16 PM
ZX1100F1's Avatar
Default Diagnostic Trouble Code (DTC) Complete list
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable DTCs in alphanumeric order with descriptors.
DTC
DTC Descriptor
Module That Sets the DTC
Diagnostic Procedure
B0000
Vehicle Speed Information Circuit
Radio
DTC B0000
B0012
Driver Frontal Deployment Loop Stage 1
SDM
DTC B0012 or B0013
B0013
Driver Frontal Deployment Loop Stage 2
SDM
DTC B0012 or B0013
B0015
Left Front Pretensioner Deployment Loop
SDM
DTC B0014-B0045
B0016
Left Roof Rail Deployment Loop
SDM
DTC B0014-B0045
B0019
Passenger Frontal Deployment Loop Stage 1
SDM
DTC B0014-B0045
B0020
Passenger Frontal Deployment Loop Stage 2
SDM
DTC B0014-B0045
B0022
Right Front Pretensioner Deployment Loop
SDM
DTC B0014-B0045
B0023
Right Roof Rail Deployment Loop
SDM
DTC B0014-B0045
B0033
Third Row Left Roof Rail Deployment Loop
SDM
DTC B0014-B0045
B0040
Third Row Right Roof Rail Deployment Loop
SDM
DTC B0014-B0045
B051A
Left Side Assist Step Motor Control Circuit
ASC
DTC B051A, B051B, B051C, or B051D
B051B
Right Side Assist Step Motor Control Circuit
ASC
B051C
Left Side Assist Step Position Sensor Circuit
ASC
B051D
Right Side Assist Step Position Sensor Circuit
ASC
B0052
Deployment Commanded
SDM
DTC B0052 or B0053
B0053
Deployment Commanded With Loop DTCs Present
SDM
DTC B0052 or B0053
B0055
Side Airbag Deployment Commanded
SDM
DTC B0055
B0056
Passenger Frontal Airbag Suppressed
SDM
DTC B0056
B0057
Right Front Side Airbag Suppressed
SDM
DTC B0057
B0058
Right Front Pretensioner Suppressed
SDM
DTC B0058
B0071
Passenger Seat Belt Tension Sensor Circuit
SDM
DTC B0071
B0074
Passenger Occupant Classification Sensor Circuit
SDM
DTC B0074
B0079
Left Front Seat Position Sensor Circuit
SDM
DTC B0079
B0081
Passenger Presence System
SDM
DTC B0081
B0083
Front End Sensor 1
SDM
DTC B0083 or B0084
B0084
Front End Sensor 2
SDM
DTC B0083 or B0084
B0085
Left Front Side Impact Sensor (SIS)
SDM
DTC B0085 or B0086
B0086
Right Front Side Impact Sensor (SIS)
SDM
DTC B0085 or B0086
B0087
Left Rear Side Impact Sensor (SIS)
SDM
DTC B0087 or B0088
B0088
Right Rear Side Impact Sensor (SIS)
SDM
DTC B0087 or B0088
B0090
Rollover Sensor Performance
SDM
DTC B0090
B0158
Outside Air Temperature Sensor Circuit
HVAC
DTC B0158, B0163, B0168, B0173, B0178, B0509, B0514, B3578 or B3583
B0163
Passenger Compartment Temp Sensor1 Circuit
HVAC
B0168
Passenger Compartment Temp Sensor2 Circuit
HVAC
B0173
Output Air Temperature Sensor1 Circuit
HVAC
B0178
Output Air Temperature Sensor2 Circuit
HVAC
B0183
Solar Load Sensor1 Circuit
HVAC
DTC B0183 or B0188
B0188
Solar Load Sensor2 Circuit
HVAC
DTC B0183 or B0188
B0228
Recirculate Position Feedback Cir
Old January 18th, 2007, 8:06 PM
engine2's Avatar
Default RE: Diagnostic Trouble Code (DTC) Complete list
Thanks ZX for another great post.
I vote to make this thread a permanent sticky.
Old January 18th, 2007, 8:10 PM
doo600's Avatar
Wow, that could come in handy. I agree...Sticky!
Old January 18th, 2007, 8:48 PM
ZX1100F1's Avatar
I listed them all from memory so if you find an error be kind.
Old January 19th, 2007, 1:06 AM
Yeah but I thought the list included a scanner. JK
Old April 19th, 2007, 11:44 AM
91BerettaGT's Avatar
Sorry to kinda bump an old thread, but is there a reason or something I would have to do to read the fixes? I have a Tahoe throwing a ****load of codes... C0226, C0245, C0246, C0251, C0252, C0265, C0281. My Modis has no "common" fix information stored in it.
Old December 8th, 2008, 3:22 PM
amrknasr's Avatar
Hi Guys, I am a new member and I just had a quick question about the DTC list posted by ZX1100F1. Specifically, I wanted to ask about the B0071 Passenger Seat Belt Tension Sensor Circuit: when is that DTC triggered? Would it, for instance, correspond to the Seatbelt warning light turning on, on the dash? For example, if my seat belt is unfastened, this DTC would be sent; if not, then it wouldn't?
Sometimes, the light just stays on even though the seat belt is fastened properly. One would almost feel it "hangs". Could this be detected by monitoring this DTC?
Any feedback you guys can provide would be greatly appreciated.
Thanks very much.
Amr
Old December 8th, 2008, 4:23 PM
Banned
shawnvw's Avatar
I am going to ASSUME you are talking about a new body style tahoe and post a common problem...
Subject:
SIR Supplemental Inflatable Restraint Message, DTC B0081, B0071 Set, MIL Light On (Repair and Reroute Wiring as Necessary)
[align=left]
Models:
2007 Cadillac Escalade, Escalade ESV, Escalade EXT[/align][align=left]2007 Chevrolet Avalanche, Suburban, Tahoe[/align][align=left]2007 GMC Yukon, Yukon XL, Yukon Denali, Yukon Denali XL[/align][align=left]with 10-Way Power Passenger Seat (RPO AG2)[/align]
[hr]
Condition
Some customers may comment that the Supplemental Inflatable Restraint (SIR) MIL is displayed on the Instrument Panel Cluster. This concern can be intermittent and could occur while adjusting the passenger seat.
Cause
When checking for DTCs, the Sensing and Diagnostic Module (SDM) will have a B0081 and the Passenger Presence System (PPS) a B0071. A possible source of this condition is the seat belt tension sensor circuits 5611, 5612, and/or 5613 being crushed in the seat riser assembly near the seat belt buckle. These circuits are in a smooth black conduit and at first may appear to be OK, but if the conduit is cut open to expose the wires, the damage can be seen.
Important:The area of concern is more easily seen if the seat is removed from the vehicle.
Correction
If there is damage to any of the wires of the seat harness then repair as necessary. If the damage is on the seat belt buckle pigtail, replace the buckle.
In order to prevent any future wiring issues involving the seat belt tension sensor circuits, the wiring should be rerouted as pictured below (refer to diagrams).
Before Reroute (original routing)
After Reroute
Important:The seat belt tension sensor circuit has been rerouted so as to run underneath the black conduit.
Once you have rerouted the circuit, tape around the plastic channel in order to hold the wiring in the channel. Refer to next diagram.
Subject:
Airbag Light On, DTC B0071 and B0081Set (Diagnose and Replace Right Front Seatbelt Buckle, if Necessary)
[align=left]
Models:
2006-2007 Buick Lucerne[/align][align=left]2006-2007 Cadillac DTS[/align][align=left]2007 Cadillac Escalade, Escalade ESV, Escalade EXT[/align][align=left]2006-2007 Chevrolet Impala, Monte Carlo[/align][align=left]2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe[/align][align=left]2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL[/align]
[hr]
Condition
Some customers may comment on the airbag light being illuminated. Upon investigation, the technician may find DTC B0071 set in the Passenger Presence System (PPS) and a DTC B0081 in the Sensing and Diagnostics Module (SDM).
Correction
Do This
Diagnose and replace right front seatbelt buckle, if necessary.
Don't Do This
Do not replace the passenger presence system or the sensing and diagnostic module.
Verify proper system electrical connections. Inspect the passenger seat belt tension sensor signal, voltage reference, and low reference circuits carefully for cutting and/or chaffing per SI instructions for DTC B0071. If all checks have been made and no fault has been found, replace the belt tension sensor.
Important:The seat belt tension sensor is not serviced separately. The seat belt buckle with the tension sensor must be serviced as a complete unit.
Old December 7th, 2013, 2:16 PM
Willard Privett's Avatar
What does fault code 0054 indicate on 07 chevy cobalt?
Old April 7th, 2014, 11:36 PM
tonto7115's Avatar
Default need help
i have a 1999 chevy suburban with dtc p0001 how do i fix it
NR16020
March 25th, 2015 11:09 PM
richo43
Silverado & Fullsize Pick-ups
July 19th, 2009 9:12 AM
ingolenssen
November 22nd, 2007 11:14 AM
Quick Reply: Diagnostic Trouble Code (DTC) Complete list
