2004 Z-71 Suburban Engine Noise
Old December 11th, 2011, 3:11 PM
glfclbs's Avatar
Default 2004 Z-71 Suburban Engine Noise
Hello Chevy Forum! I have a 04' suburban z 71 with a funny noise in the engine compartment. It sound as though it could be a belt squeek but isn't. It is a steady noise and appears to be coming from the engine on the passenger side. I took a piece of hose and stuck inside the oil filler tube, and it seems to be coming from inside. I have pulled the valve covers and it is oiling through all of the push rods and doesn't seem to have a bent one? A friend told me it could be a bad lifter but at this point, I am lost. any help would be greatly appreciated. Thanks to all for your time in advance, this forum has been a great tool for me!!!! Mike
ps. forgot to mention it has 131,000 miles. Engine is really clean.
Old December 11th, 2011, 3:47 PM
shamrock246's Avatar
try taking the belt off and see if it go's away it should run without it for long enouph to see
Old December 11th, 2011, 6:38 PM
glfclbs's Avatar
I tried both belts already and thanks for the comment. I also pulled both valve covers off and really didn't see anything. Engine is very clean with no build up. Almost sounds like a push rod rubbing the head on an older motor???
Old December 11th, 2011, 11:12 PM
NMguy's Avatar
Could be the belt tensioner. These things produce a strange squeak. I found this to be the culprit most of the time. last time I thought I had a bad fuel pump, the sound throws that far under the truck. then I though a belt, lifter. etc. Turns out it was the belt tensioner going bad. happened to me twice.
sometime these things squeak when the truck will start up for a few minutes. replace the tensioner and see if it goes away. if not, check your water pump.
Old December 14th, 2011, 8:42 PM
Doubt it's the tensioner since he said he pulled the belts and it still made the noise.
Old December 15th, 2011, 4:24 AM
NMguy's Avatar
could be a bad spring on the lifter itself. thats the only thing I think would squeak like that.
Michael Criswell
September 8th, 2013 3:07 PM
Melody Smith Arquillo
December 3rd, 2012 12:48 PM
dutch1724
October 30th, 2012 11:02 PM
chevyhardy
May 11th, 2010 9:35 PM
bigdirtmcgirt
August 30th, 2008 10:20 AM
Quick Reply: 2004 Z-71 Suburban Engine Noise
