Uplander 2005-2009
Platform: U-Body
C0035 C0036 C0040 C0041 C0281 codes
Old May 16, 2012 | 10:59 AM
uplander06's Avatar
Exclamation C0035 C0036 C0040 C0041 C0281 codes
nevermind, figured out
Old Jun 10, 2012 | 11:04 PM
edmonton58's Avatar
Red face Need Help. Having the exact same codes with ABS light on.
Please help. I have a 2006 Chevy Uplander. The ABS light is on. After taking the vehicle into a shop for a quick scan. The codes are c0035, c0036, c0040,c0041, and c0281. Can you tell me how you fix your car?
Old Jun 11, 2012 | 12:02 AM
uplander06's Avatar
mine was a bit different, from my understanding the C0281 code comes up when both of the abs fail. in my case both were bad, but we only replaced left and never cleared the code after. so down the road we replaced the right hub, and cleared the codes and now everything is fine. So if you already have the hubs replaced then just clear the codes, if not, replace both hubs and then clear codes. Obviously check the wiring first, the wires that come out of the hub and connect to wires and going to whatever, it might just as simple as a bad connector, but most likely just its a failed abs. its not bad to replace them yourself, took us maybe 1.5hrs each side.
Old Jun 13, 2012 | 12:29 AM
edmonton58's Avatar
Default ABS light cleared. Common problem for the Uplander!!
Thanks for the tips. I checked the wires that lead to the hub with my mechanic. The connectors appear to be good, but my mechanic pull out the wire from the conduit and pull lightly. The wires just break easily. Apparently, GM wrap the wire with hard tape that is not flexible, and the wires are just too short for the maneuvering of the wheels. Over time, it will get broken inside. I cut the wire and put an extra 3 inches of wire on it. The ABS light just clear itself.
Old Oct 2, 2022 | 5:43 PM
MadDog63's Avatar
Default So, what was it? I have the exact same codes.
I know it has been a long time, but do you happen to recall what was causing it? I have the exact same codes. That is the value of these forums, so if you figure something out, please post it instead of saying "nevermind".
cdnskipatroller
Uplander
26
Sep 25, 2017 2:31 PM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
sierra_5300
Dec 9, 2010 10:32 PM
valkire17
Sep 11, 2010 9:35 AM
slingblade
Jun 8, 2006 2:57 PM
