1997 Chevy Silverado C1500 (5.7 V8) RPM/Speedo stuck at 0.
Old Jun 2, 2021 | 11:08 PM
AlexVelasco805's Avatar
Default 1997 Chevy Silverado C1500 (5.7 V8) RPM/Speedo stuck at 0.
My check gages light is on. And my RPM/Speedo are stuck at 0 and the truck won’t shift out of first gear. I don’t remember the exact codes but one was for the MAF sensor and I replaced that, one was for the 02 sensor past the catalytic converter, replaced that. And one was for the ECM. I have one on the way but any other ideas on what’s happening?
Old Jun 4, 2021 | 12:18 PM
Gumby22's Avatar
What code led you to think the ECM needs to be replaced? I wouldn’t install a new one until you’re sure it actually needs to be and there’s not an external reason (shorted wiring for example) that caused it to malfunction in the first place.
A code does not necessarily mean a component should be replaced. They’re more like clues in a scavenger hunt - they don’t tell you what the problem is they just give you a place to start looking.
Inspect the wiring harness under the driver side dash near the bracket for the parking brake pedal - some have been known to rub through the insulation and cause the issues you’re describing.
Old Jan 10, 2025 | 12:35 PM
Capod1983's Avatar
Default 97 silverado c1500 doing same thingʻ still need help!!@
having same exact problem but my code reader is pulling up torque converter clutch,and silonoid codes.
changed the vss didn't do anything.
Still have the problem. Help.
HarryBeckmann
1988 - 1998 (GMT400)
Jan 3, 2016 9:39 AM
donniej
Apr 8, 2014 12:28 AM
samsaridinc1500
Apr 27, 2013 11:53 AM
JoseJR
May 17, 2011 9:51 AM
davo davis
Jun 20, 2007 5:33 PM
