1997 Silverado 5.7 weird starting issue
Old Mar 10, 2019 | 7:45 PM
  #11
Irish_alley's Avatar
I'm here for the party
wonder if the fuel pump relay has arcing damage from years creating an internal resistance
Old Apr 26, 2019 | 11:35 PM
  #12
Terminal Frost's Avatar
You have a Vortec?
Whole different injection system with the poppet tips.
I would start to inspect those.
From what you say, your fuel delivery to the spider injector appears perfect.
Old Apr 29, 2019 | 4:11 AM
  #13
Kenneth Brown's Avatar
Check to make sure the o-ring between the throttle body and the air breather is installed correctly and/or not damaged or missing.. If it's not correct or is missing it screws with the MAF readings. Basically it's a vacuum leak and can cause long cranking issues. Shows up as negative numbers when you test your long term fuel trims.
