1999 5.7 tahoe heater, coolant leaks issues
Old Nov 30, 2020 | 8:50 PM
Shank69's Avatar
Default 1999 5.7 tahoe heater, coolant leaks issues
My tahoe runs great other than the fact that it sounds like water sloshing in the heater. I had this problem last year, and it was because there was bubbles in the coolant after it had been refilled. This year, it sat for about a weak, and I noticed a leak coming from the transmission cooler screw on the radiator. There is again a sloshing sound in the heater, and now it only runs on high. Any help or suggestions would be greatly appreciated.
Old Nov 30, 2020 | 11:12 PM
oilcanhenry's Avatar
Your heater should be full of coolant. If not, that is why it's sloshing. Something is blocking the coolant. Might be a bad hose or the inner portion has deteriorated to the point of its blocking a good coolant flow.
Snake17
Feb 4, 2019 5:39 PM
mistaake
Mar 24, 2015 10:37 PM
gaftop1
Apr 8, 2012 12:33 PM
isrummell
Dec 6, 2011 6:01 PM
twenty8
May 22, 2008 7:21 PM
