327 swap from 350
Old Jun 22, 2022 | 10:09 PM
Walt39's Avatar
Default 327 swap from 350
I have a 94 silverado that has been sitting 4 years that my step dad knows of. It was ran hot and left to die. Now the 4 and 6 cylinder is seized up from rust. I have a 327 with a 2 barrel carb that runs I want to put into the truck. The trans is a 4l60e-2wd. I know I have to remove the electric fuel pump and drain the old gas, then run a bypass for the manual pump. The 350 had a throttle body injection system on it with a/c. I know how to do the a/c work. I just want to know if there is anything in particular I will need to do in order to make this swap work in my favor, seeing as the only other ride I have is a 95 jeep cherokee that need a lot of tlc.
Questions that arise, Will the trans bolt up and work correctly?
Will the engine accessory brackets will bolt up and work?
Which wires am I looking to tap into to make the engine start and stop with the key?
Any help or pointers would be greatly appreciated.
Old Aug 5, 2022 | 9:53 AM
Bryguy123's Avatar
Default 327
1995 silverado, Vicky Valencort is her name. I just purchased the truck a little over a month ago. It has the 327 swap, with 350 heads and I am assuming the intake, because it still has the TBI set up. I had to make a quick decision and purchase the truck in a short time frame. I am learning as I go because she needs just a little TLC. If I can refer to my truck and help you with some things, please contact me. I will probably learn something also.
WTFRUDOIN
Jul 22, 2021 10:38 PM
Raz Cue
Nova & Chevy II
Mar 16, 2021 9:34 PM
BigD67
Dec 2, 2017 11:49 AM
