88 5.7 Intermittent Check Engine Soon
Old Feb 11, 2024 | 10:01 AM
blueseasons's Avatar
Default 88 5.7 Intermittent Check Engine Soon
I did a ton of work on it last year. New MAP, and Ignition Module, new O2 Sensor. New distributor. Its been running great. Took it on a 70 mile ride yesterday and on the last leg the CES light came on.
After I got home. I turned it off and then back on and the CES light didnt come back. Its early the next day and I havent checked yet for codes. Any suggestions as to what to expect?
It did this a few times last year before I did all that work and before replacing the catalytic converter. I have smog due next February so I have a year to figure this out. There was no change in the engine after the light came on.
Old Feb 11, 2024 | 5:48 PM
could be many things. You need to check for codes. It's incredibly easy you can use a paperclip.
Old Feb 12, 2024 | 10:17 AM
I know. No codes. I thought once the light went out. Codes are not stored.
Old Feb 12, 2024 | 3:59 PM
They are stored in OBD-II systems. Not sure about OBD-I but it's worth a try.
Otherwise you'll have to wait for it to come back.
Old Feb 12, 2024 | 4:15 PM
Iam more familiar with the OBD2.I "think" what "may" have happened is the vacuum hose to my EGR valve slipped off. My old-school egr valve had a brass port to attach the hose. I needed to replace it a couple of years ago and the new one came with this plastic swivel connector. I had to bring it to a place to get it smogged and the guy broke the plastic connector off for me. I had the rubber hose glued to what is basically a brass nub that the plastic thing fit on . The nub isnt long enough to attach the vacuum hose directly. So this time I epoxied a L Shaped adaptor onto the egr valve nub and attached the hose to it. I think I may have gotten the light because the hose wasnt connected very well.
The epoxy will set by tomorrow and ill see what happens., Shoots. I can remember when an EGR valve for a chevy was $15.00. Now they are double that for an aftermarket no-name valve. Since this one is only 3 years old, im trying not to spring for another one.
jr70895
2007 - 2013 (GMT900)
Oct 14, 2021 3:24 PM
bodatiouskid
Jul 27, 2017 4:41 PM
Dave Brown
Sep 23, 2012 8:46 PM
this kid again
Jan 12, 2012 2:24 PM
lebasque
Dec 12, 2010 7:15 PM
