95 GMC 1500 Clutch Hydraulic system
95 GMC has a closed system (no bleed). My truck is at 286k miles with the original system parts still in place. The hydraulic line recently blew out so I ordered a a complete new system from Rock Auto but am having difficulty snaking the old one out. I'm trying to keep it intact so I can reverse the process with the new parts. Any hints as to ease it loose? Should I be feeding/pulling from the top or the bottom?
It’s unlikely to make much difference, but please provide engine size, chassis (1500/2500/3500) and w/ or w/o 4x4.
The exact removal process can also vary depending on what emissions systems are on it (ex. w/ or w/o smog pump system).
Also which kit did you purchase?
Hello Gumby22, 95 GMC 1500 2wd 5.7 motor, 5 spd .no smog pump with Gibson headers that y connect just to the rear of the slave cyl. I had no problem getting the slave cyl unbolted and pulled out. My new unit assy is a SACHS p/n S2 SPH044. Thanks for your help.
makingaZJ
June 27th, 2011 11:25 PM
