98 k3500 ECM Fuse Blowing
Old Dec 10, 2020 | 2:23 PM
_Your Worst Nightmare_'s Avatar
Default 98 k3500 ECM Fuse Blowing
Hello all this is gonna be a long ride so buckle up. I have a 1998 k3500 Silverado 4x4, and about 5 and a half months ago my engine shut down while I was driving it (luckily it was in the driveway) and since then we have changed out the fuel pump, fuel pump relay, and the ECM Fuse. And since replacing everything any time we try to crank the engine over mind you sometimes the engine even fires up but it immediately shuts off again and blows the ECM Fuse. I'm not sure what could possibly be causing it as I'm not big on working with electronics, but if anyone can possibly give me some options to try i really cannot afford to take it to the shop. Any help would be appreciated! Also guess that wasn't that long of a ride.
Old Dec 10, 2020 | 2:28 PM
kevinkpk's Avatar
Little more history as why you replaced the fuel pump etc. You have a short in the circuit. I'd suggest based on "assuming" this happened since you replaced the fuel pump/and relay. If that is the case, unplug the fuel pump connections including the rerelay, see if the fuse blows. If not track it down from there.
Old Dec 11, 2020 | 2:00 PM
we had figured out the fuel pump relay and ECM Fuse were blown and had changed those out and the pump was still not turning on so we replaced the pump and it had started up but one of the fuel lines was spraying gas so we had to replace the fuel line connector and after we replaced the connector the ECM fuse kept blowing and wont start anymore.
Old Dec 11, 2020 | 2:10 PM
kevinkpk's Avatar
[QUOTE=_Your Worst Nightmare_;457329]we had figured out the fuel pump relay and ECM Fuse were blown and had changed those out and the pump was still not turning on so we replaced the pump and it had started up but one of the fuel lines was spraying gas so we had to replace the fuel line connector and after we replaced the connector the ECM fuse kept blowing and wont start anymore.[/Well, is the fuel pump fuse still blowing with the ECM fuse?
Old Dec 11, 2020 | 2:11 PM
kevinkpk's Avatar
Old Dec 12, 2020 | 9:54 PM
Gumby22's Avatar
Which fuse? ECM 1 or ECM B? Fuse 1 powers the injectors, crank sensor, ignition coil, ignition control module, and is an ignition input to the ECM. Fuse B powers the oil pressure switch, fuel pump relay, and is another ignition input to the VCM.
Depending on which fuse is blowing will depend on which components you need to check, but you’re most likely looking for a loose/corroded connection. If it’s fuse B, the harness between the under hood fuse block and fuel pump, under the cab, is a problem area for these trucks, particularly if it’s been tapped for accessory power.
Old Dec 13, 2020 | 8:01 AM
hanky's Avatar
As you know, a fuse blows when the current amount it is allowed to pass gets exceeded.
After you determine what that fuse supplies power to you can connect a load like a headlight lamp or test light across the fuse contacts in the panel and you will have a visual indication of when the short is eliminated when the light goes out. You will need to move wires away from sharp areas and move harnesses each time watching if the light goes out. If you do not watch every move you will never know where the problem was and , they always return !
XmoDDeR
Dec 4, 2019 2:52 PM
plekachu14
Jan 17, 2014 8:05 PM
halfton1500
Jan 15, 2014 6:59 AM
netty
Oct 23, 2009 12:04 AM
jommer
Sep 24, 2008 9:49 PM
