97 k1500 turn signals and reverse lights not blinking, but the hazards work fine.
Old Feb 21, 2020 | 5:38 PM
tempma7's Avatar
Default 97 k1500 turn signals and reverse lights not blinking, but the hazards work fine.
I have a 1997 Chevy K1500 5.7 and the turn signals and reverse lights are not working. The hazards, runnings lights, and tail lights all work. I have replaced the multifunction switch, signal flasher, and checked all the bulbs. Not sure if this is related, but my cruise control doesn't work either.
Another issue I am having is with the idle. It is very rough, shaking the whole truck, when at idle and low rpm. I am getting a P0300 code and I know that means it is misfiring. I replaced the spark plugs and wires but I am still having the issue. I have an exhaust leak out of the manifold that is starting to leak into the cab. Would the exhaust leak cause the misfire code?
Old Jun 25, 2020 | 4:39 PM
Koltyn Swango's Avatar
Mine is having the same problem if you find a solution let me know
Old Jun 25, 2020 | 5:28 PM
Welcome from Florida. Check all of your fuses, do not overlook the obvious. An exhaust leak should not cause a misfire but a plugged cat or muffler could cause that. last week I replaced the distributor cap and rotor on my son's S10 Blazer. It ran good for a day or so then P0300 and later no start. My friend has a shop and said it is the cap and rotor I bought from Pep Boys. We replaced the distributor this time to take no chances and it runs great again. Beware of buying cheaper aftermarket parts.
Old Dec 16, 2020 | 7:32 PM
Brody Bailey's Avatar
Default Help
I am having the exact same issues pretty much every single thing you said. Except I haven’t checked codes yet. Did you ever find an answer.
Daniel Collins
Dec 29, 2019 9:12 PM
Gregory Hoard
2007 - 2013 (GMT900)
Jun 17, 2019 11:19 AM
ChevysOrDeath
Silverado DIY and Useful Threads
Oct 29, 2018 9:42 AM
CUERVO17
Apr 25, 2016 10:52 AM
bigbadb78
Oct 21, 2011 8:15 PM
