Bright light indicator
Old Nov 16, 2024 | 12:10 PM
cublex's Avatar
Default Bright light indicator
My bright light indicator stays on even when I switch back and forth between low beam and high beam...1993 Chevy C1500
Old Nov 16, 2024 | 1:38 PM
Gumby22's Avatar
Are you sure the headlights are actually switching to low beams?
The indicator lamp is just an additional branch off the high beams circuit - if the headlights are actually on low beams, it’s likely there’s a short to voltage within the cluster.
Old Nov 16, 2024 | 1:42 PM
cublex's Avatar
Yes they are switching back and forth indicator on the dashboard stays on
Old Nov 16, 2024 | 7:26 PM
Gumby22's Avatar
Try unplugging the dimmer switch and see if it turns off.
If yes, use a jumper between the power in and low beam circuit. If the indicator is still off, the dimmer switch is keeping just enough contact to light the indicator but not enough to pull adequate current for the high beams to remain on.
Jshow
Cobalt
Dec 3, 2025 12:39 PM
Jeremybowman
May 21, 2017 7:37 PM
LuannR36
Apr 6, 2017 3:13 PM
atvkid4eva
May 24, 2013 7:07 AM
rabbit0102030
May 20, 2008 11:02 AM
