Carb to TBI swap
I bought a 1994 K1500 Z71 stepside that had been swapped with a carburetor... I'm attempting to swap it back to stock TBI... I have the Intake manifold, Throttle Body, most of the connectors, and most of the air cleaner housing... The stock wireing harness is still there so that makes it easier, but I'm not sure about the wires to the actual injectors in the Throttle Body or where to run them to... Any tips, pictures, diagrams, and advice is much appreciated. Thanks
https://fuelinjectionconnection.com/gpage5.html
Reconyx_01 (November 21st, 2019)
I found this information IRT your conversion back to a TBI unit from a carbuerator. I hope the information contained therein will help you to convert your 1994 Chevy back to an operational TBI fueled pickup, Reconyx_01.
oilcanhenry (November 21st, 2019)
Glad to hear it. That's what I would have done too.
The injector wires go straight to the ECM. Find a pinout for your vehicle year. #1 injector is usually on the blue connector, and the remaining injectors are usually on the red connector. There is a hot going to each and a signal wire. There is a connector that sits inside the harness of the spider. The cylinder numbers are on the spider assembly and inside the manifold, so it's pretty easy to match everything up and trace the wires back. If you don't already have the injector assembly, get the MPFI one.
Here's a connector pinout for the ECM for any lurkers. It sounds like you won't need to do any wiring with the original harness intact.
https://troubleshootmyvehicle.com/gm...ctor-pin-out-1
Bigtank
July 27th, 2019 6:35 PM
wagn6137
11
October 4th, 2011 6:49 AM
