Clutch Replacement 1993 K1500
Old Apr 27, 2024 | 12:11 PM
rehoward's Avatar
Default Clutch Replacement 1993 K1500
I am about halfway done with replacing the clutch in my 1993 K1500 4wd truck. What a pita it has been! Frozen exhaust bolts, sheared off exhaust studs, stuck crossover pipe. I even needed to remove the exhaust manifolds because the 3 studs on each side sheared off.
I finally got the cross over exhaust pipe removed, the drivelines removed, and now am ready to drop the 5 speed trans and transfer case.
My concern is, can I just unbolt the bellhousing and shove the trans/transfer case toward the rear of the vehicle or do I need to completely drop them out as a unit to gain access to the clutch and flywheel? This really has been a job from hell and I need to get it done. I jacked the truck up and it is sitting on stands 12" higher so I am crawling around under it doing the work.
If anyone has tips for accessing the clutch for replacement and dropping the trans/transfer case I would really appreciate some advice.
Thanks for your help.
Randy
Mkm@120
1988 - 1998 (GMT400)
Apr 18, 2022 10:29 AM
worldofhurts
Jul 7, 2020 6:34 AM
Pocho86
Jun 6, 2014 12:47 PM
Redneck9694
Aug 13, 2013 8:42 AM
suzuki-guy
Apr 24, 2009 7:12 AM
