Coolant mix not quite right
Old Sep 18, 2021 | 5:31 PM
Jesse9657350's Avatar
Default Coolant mix not quite right
1996 Z71 1500 5.7L
Basically straight water was added to the radiator, not distilled, about half gallon, maybe a tad more. This was done while filling it with the correct 50/50. So the ratio is a little off should I be concerned about this? The temp gauge when warmed up now is a few flicks under the standard 210 operating temp, it doesn't seem to rise above that after driving for a while.
. I was thinking of doing a flush anyway, any good ideas or tips on a system flush? I've heard of people using straight water and mixing a cleaner in, running it for 15-20 min, dumping that and starting over with fresh 50/50.
Any tips or help is appreciated thank you
Old Sep 18, 2021 | 7:08 PM
dump a gallon and add a gallon on non mixed coolant.
Darrell Matthew Smith
Aug 15, 2019 8:52 PM
BenAyres14
Jul 19, 2012 1:54 PM
pacey
Sep 19, 2011 1:59 PM
GregHamilton
23
Jul 18, 2011 12:14 PM
tom5170
Jul 6, 2010 2:14 PM
