Dual fuel 97 Sierra no power to fuel pump all fuses and relays good
Old Oct 19, 2024 | 9:45 AM
Adena's Avatar
Default Dual fuel 97 Sierra no power to fuel pump all fuses and relays good
I recently purchased a 97 Sierra that has been converted to dual fuel(which I know nothing about BTW)the truck ran when purchased but leaked massive amounts of water so I replaced water pump and lower hose .then she wouldn't start so I tried all quick fixes I could think of ( starting fluid and so on ) but due to the dual fuel thing figured I'd just replace fuel pump on gasoline side and still nothing no start actually I don't even hear the pump engaging and yes the propane system is temporarily unhooked due to having to get to the in tank fuel pump so my question is help please
Old Oct 21, 2024 | 1:27 PM
jfmorris's Avatar
I would check the fuel pump relay. If the vehicle is dual fuel, there still needs to be some type of switch to select if you are running from gasoline or the propane tank in the back. So I am betting the fuel pump is disabled electrically in some fashion. The propane would have to enter the engine in a gas form at the throttle body and/or fuel rail somehow, bypassing the normal fuel lines coming from the gas tank. I would be looking for some type of switch under the hood, for the fuel source, and for a switch (or missing relay of fuse) that is disabling the gasoline fuel pump.
Old Oct 21, 2024 | 4:14 PM
Rednucleus's Avatar
If it ran before yhou replaced the water pump, retrace your steps and see if something was left unhooked
Old Oct 21, 2024 | 8:10 PM
Adena's Avatar
Yes propane runs in at the fuel rail and no no missing or unhooked anything
Old Oct 21, 2024 | 8:11 PM
Adena's Avatar
Default Retraced
I have retraced everything and nothing seems to be different no loose wires no missing parts
patlsan
Sep 22, 2014 11:44 PM
jpm1207
Aug 25, 2010 8:05 AM
grejohn
Oct 12, 2009 1:02 PM
aartod
Sep 30, 2009 3:48 PM
Enstar
13
Jun 22, 2007 10:36 PM
