Front Parking Lights Not Working
Old Feb 13, 2020 | 8:23 PM
Ces3857's Avatar
Default Front Parking Lights Not Working
I have a 1994 K2500 and the front parking lights aren’t working. The turn signals work and the headlights also work; however, the steady burning parking lights and the corner marker lights do not work. I changed the bulbs in case the lower filament was out and it didn’t fix the issue. What would be my next step? All the fuses I checked were good.
Thanks!
Old Feb 16, 2020 | 12:12 PM
Irish_alley's Avatar
I'm here for the party
inspect the grounds. should be one right there in the wire harness. are you getting B+ at the light socket?
Old Feb 16, 2020 | 12:34 PM
Ces3857's Avatar
What does B+ mean? Sorry I’m clueless when it comes to electrical. I’m trying to trace the electrical harness now but that’s proving difficult as the previous owner mounted a winch under the front bumper. Are there specific spots I should look at first?
Old Feb 16, 2020 | 4:23 PM
Chris94's Avatar
What's that aftermarket switch for? I'd follow it's wire as well and see where the PO spliced into. That could be a potential for an issue if the splice wasn't done well and the wires corroded. I had to look up the B+ voltage too, and here's what I found.
"B+ voltage refers to the voltage found at the positive terminal of your battery. With the engine off, this is typically a bit over 12 volts positive, engine running it should be more like 14.4 volts."
Old Feb 16, 2020 | 4:26 PM
Ces3857's Avatar
Winch not switch, sorry my phone’s spell check gets the best of me sometimes
Stoner
Cruze
Dec 5, 2015 10:22 AM
Doug Roberts
Sep 29, 2012 12:12 PM
ChevyTruckowner512
Mar 23, 2012 4:54 AM
mudderfan
Nov 11, 2007 5:17 PM
charlie93chevy
Apr 21, 2007 5:52 PM
