Gas fouled plugs
Old Nov 8, 2019 | 3:02 PM
NickGraves55's Avatar
Default Gas fouled plugs
I have a 1998 k1500. I left it sitting for 2 days and it would not start. Turns out my plugs wer gas fouled. They had deposits and were wet on all 8 plugs. I cleaned them up and the truck ran fine. After about 3 days it started having the same problem. I’m not to sure what I should test other than the fuel pressure regulator, the fuel return line and maybe the injectors for leaks? Is it possible for all 8 injectors to start leaking at the same time? It has the 5.7L engine in it with the spider injectors. Any help would be greatly appreciated!
Old Nov 8, 2019 | 6:30 PM
so it's running rich right. Check mixture related sensors. MAF etc.
mm66
Feb 8, 2020 5:05 PM
Chevyordie
1988 - 1998 (GMT400)
Sep 25, 2017 10:22 AM
MDTAHOE
Mar 25, 2010 10:32 PM
jharrisman
Sep 20, 2009 6:04 PM
hatleyjm2000
Mar 25, 2008 10:31 AM
