K1500 lacks power
Old Feb 10, 2024 | 8:05 PM
dom1219's Avatar
Default K1500 lacks power
1993 Chevy K1500 5.7L 350 TBI with 165k miles runs very rough on cold start until warm it smooths out. While driving it's very sluggish/lacks power under load around lower to mid-rpm range.
I've replaced multiple parts including; EGR Valve/Sensor, Fuel Filter, Throttle Position Sensor, Ignition Distributor. I've been told that it most likely needs an intake manifold gasket. Just wondering if I should check anything else before I dive in and what else I should replace if I take off the intake.
Old Feb 10, 2024 | 9:28 PM
Originally Posted by dom1219
what else I should replace.
less replacing , more diagnosing.
the usual stuff, air filter spark plugs. Measure fuel pressure, check for vacuum leaks...
Old Feb 13, 2024 | 10:20 AM
dom1219's Avatar
Couldn’t find any vacuum leaks when i checked, that’s why i’m thinking it’s intake gaskets, figured when it warms up the metal seats better
K1500Meatwagon
Mar 27, 2023 11:11 PM
Sam Boyer
1988 - 1998 (GMT400)
Nov 11, 2018 9:31 PM
diver8718
Jan 13, 2015 5:15 AM
Zuby
K5 Blazer
Jun 19, 2011 2:15 PM
chevyfan78
Feb 18, 2010 11:28 PM
